Copy and paste effects between premiere pro and after effects
  • January 30, 2023
  • 4611 views
Hi
Is there a way to copy and paste effects between premiere pro and after effects, e.g. Lumetri Color, and maintaining the adjusstments?
To Copy and Paste effects between clips in Premiere is possible — Let me show you two different ways:
A) Using the Effects Controls Panel
  1.  Open up the Effect Controls Panel and select the Lumetri Color effect
  2. To copy this effect, including the settings: Press CMD+C (or CTRL+C for Windows)
  3. Now select another clip and 'paste': Press CMD+V (CTRL+V for Windows)
B) Copy and paste attributes from the clips directly in your Sequence
1. You can also copy a clip in your sequence —
2. Then Paste the Clip's Attributes to another clip (Right-Click the target clip, and select 'Paste Attributes')
This way, you can paste multiple properties like:
  • Motion
  • Opacity
  • Effects
Thanks for you reply. However, the questions was if it is possible to copy from PP and paste in AE
No...Interesting question. You can right click on a clip in Premiere Pro and replace with After Effects composition which would bring the clip with the adjustments into After Effects if that helps,
