Jun 6, 2024 8:30 AM UTC
Copy-Problem by Premiere 24.4.1
Hey! With the new update of Premiere 24.4.1 I have problems with copying clips. I always have to copy the respective clip twice with command + c before it is copied by Premiere. My colleagues have similar experiences. Do you have the same problem and do you know if there is a workaround?
Thank you!
MyerPj
MyerPjCorrect answer
Jun 29, 2024 6:58 PM UTC
I just tried it in the beta 24.6.41 and it worked as expected.
ANT.Rose
Jun 10, 2024 7:15 AM UTC
Similar problem here! Love the new interface and colors but the copy/paste command not working properly is a problem. The using command+v double helped me for now, thank you, but I hope there will be a less twitchy solution soon.
I tried reseting the copy/paste commands in keyboard shortcut to other commands than command + c/v but this didn't make any difference.
Jun 6, 2024 10:11 AM UTC
did you try resetting the preferences?
