Corner Pin problem in Premiere Pro
  • December 10, 2023
  • 45 replies
  • 8904 views
I have a problem in premiere pro, with corner pin. After aplying, it makes some black lines.
Correct answer Ann Bens
It has been fixed: 24.2.1. or use beta.
Same here, still no cure for this
Roll back a version or use the beta.
Yes, it works, I upgrade to Beta version & back to normal
Known bug. No solution yet.
So it is not a problem with my graphics card.
kglad
<"moved from cc desktop bugs">
FrédéricChabot
im getting black lines in my images when using corner pin
it appears in the program monitor and in exports. it changes like moiré when i adjust it..
it disapears when corner pin is disabled
anyone know if this is normal or a bug? thx
windows 11
13th Gen Intel(R) Core(TM) i7-13700F
32 gb
RTX 4060
premiere 24.1.0 build 85
I have seen this with corner pin
