Create a Multi-Camera Sequence using Sound Timecode option
  • July 30, 2018
  • 3267 views
Hi There,
I want to create a Multi-Camera Sequence using the Sound Timecode option to synchronise files.
It seems Premiere Pro is not reading the Sound Timecode track!
Ben
    You may have to choose another method.  I've always preferred the following.
    Manual Multi-Camera Method
    Hello Jim,
    Thanks for the answer and the elegant proposition to create multi-camera.
    We really need to use the Sound Timecode option, synchronising manually is going to be a waste of time we dont have.
    ben
    Well, would it have taken longer than the 12 hours you waited for another answer?
