Feb 17, 2025 10:08 AM UTC
Create custom resolution sequences from a spreadsheet using Automation blocks
Hi!
I would need to create many custom sequences for a project, they all have a custom resolution (all at 25fps), examples:
336x672
1024X512
1080x1920
2048x512
3120x1248
1872x936
And many more...
I was wondering if there was a way of creating all these sequences with the help of Automation Blocks, retrieving the height and width needed from a spreadsheet would be ideal.
As doing more than 30 of these sequences manually would take a long time.
Hope there's a solution, many thanks!
Mathias Moehl
Mathias MoehlCorrect answer
Feb 17, 2025 12:34 PM UTC
You can create a custom Automation Blocks script which creates a new sequence using the
New Sequence from Preset  block. Just use multiple copies of the block to create several seqences.
If you want to read the sequence names and sequence preset files from a spreadsheet, combine it with a
For Each Row/Column of Spreadsheet block as follows:
The code assumes that
- the first column contains the names of the new sequence (optionally with a bin like "bin\subbin\sequence")
- the second column contains the file path of a sqpreset file (sequence preset) see how to create such sequence preset files.
(block code is attached)
Mathias Moehl
Feb 17, 2025 12:49 PM UTC
Hi Mathias, thanks a lot for your solution!
If I undestood it correctly I would still need to have a sqpreset file already made before running the script, correct?
Because the issue I'm having is that for every project the resolution needed is so different, that I would need an infinite amount of formats in order to create all possible combinations.
I've thought about creating it with the preset file option but I don't know what resolution I will need to create per project, therefore a more dynamic approach would be needed, is there any solution inside Automation blocks? Or for this case some JXS is needed? I have attach an example of the spreadsheet with some resolutions.
many thanks again!
Mathias Moehl
Feb 17, 2025 2:12 PM UTC
As far as I know, new sequences are always created based on a preset and their widht and height cannot be changed later using scripting. Therefore, I don't see a way of creating sequences automatically without creating preset files for them in advance.
BUT
sqpreset files are normal xml files (i.e. text files) so you can create them with Automation Blocks.
This script writes for each row of the spreadsheet a file "temp.sqpreset" on your desktop and then uses this sqpreset file to create a sequence of the respective size.
I didn't test this code but I think it should work:
Feb 17, 2025 10:27 AM UTC
I takes me about 15 seconds to make a custom sequence, in 10 min I could have made more than your 30. It would take longer than that to make a spreadsheet and write a script.
Feb 17, 2025 10:29 AM UTC
Hi, yes that is true. But I often have this types of project, so in the long run automating it would save time, it's not this one project, and the resolutions are always different.
Feb 17, 2025 10:32 AM UTC
Also I need to rename the sequences based on the resolutions, here mystakes can occur too, when doing it for 30 or 40 times
Feb 17, 2025 10:16 AM UTC
Hi, thanks for your reply. I currently need it for Premier Pro 2024 only.
I've been trying to find a way on how to implement it, but struggling a bit to find the right Scipt to add using Automation Blocks.
