Creating an audio track after soloing a different audio track does not mute the new track.
- July 25, 2024
- 1 reply
- 333 views
- Issue - Soloed audio track does not stay soloed when new audio track is created.
- Adobe Premiere Pro version number: Version 24.5.0 (Build 57)
- Operating system - Windows 10 Home
- System Info: CPU, GPU, RAM, HD:
Processor Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz 3.70 GHz
GPU Nvidia RTX3700
Installed RAM 64.0 GB
System type 64-bit operating system, x64-based processor - Video format:
- Type: Waveform Audio
File Size: 70.33 MB
Source Audio Format: 48000 Hz - 24-bit - Mono
Project Audio Format: 48000 Hz - 32 bit floating point - Mono - Workflow details: This is just cutting a voice over track with nothing else in the timeline. Just a few tracks of audio where each takae of a vo line is on a new track of audio.
- Steps to reproduce - (Very important!)
1. Lay audio onto track A4
2. Solo Track A4
3. Use Add Edit keyboard shortcut to slice the track.
4. Drag a piece of audio from track A4 to the space below the Mix in order to create a brand new track A5.
5. Play the timeline - Expected result - I should not have heard the new clip on audio track A5 since track A4 is soloed.
- Actual result - I heard audio from both tracks A4 and A5.
