mikecox_
Ctrl-D didn't add my default transition
  • March 27, 2018
  • 4360 views
I'm between clips on the timeline and hit Ctrl-D, expecting the default transition to appear, but nothing happens.
So I go to the Effects Panel and drag my default transition between the clips and the transition appears.
Why didn't the shortcut add the Transition?
Correct answer Ann Bens
Humm
   I get the transition if no clips are selected. But that puts a transition between all my clips, doesn't it?
If I select the clip and put the playhead between the clips then hover over the end, til the icon appears; the the double arrows, then click Ctrl-D nothin happens.
No.
Just select the cut with your mouse, not the clip(s).
mikecox_
mikecox_Author
Thanks for that, very helpful.  I've been wondering how those options were used. So yes, the tracks are Targeted.
I have tried applying the transition to the clip I want to add a transition to, and I have tried going to the Sequence that the clip is in but Ctrl-D will just not add the transition.
Surely I'm doing something wrong, but what?
Using Win 11
mikecox_
mikecox_Author
Post screenshot of your timeline with trackheader and clearly where you want the transition.
Source Patting does not light up in the Sequence, just in the clips.  I don't understand, just sayin.
Is this what you need?
Using Win 11
