Cursor Calibration Issue in Premiere Pro with External Monitor
Hi everyone,
I am experiencing a serious issue with cursor calibration while using Adobe Premiere Pro on my external 4K monitor. The problem makes it impossible to accurately drag or move clips on the timeline, as the elements do not respond correctly to the cursor’s position.
I have already tried the following troubleshooting steps without success:
  • Uninstalling and reinstalling Premiere Pro
  • Resetting settings to default
  • Clearing the media cache
Interestingly, the issue only occurs on my external monitors, whether connected directly to my Dell Alienware M15 laptop or through a docking station. On my laptop’s built-in display, Premiere Pro functions normally.
I would greatly appreciate any guidance on how to resolve this issue. Please let me know if you need any additional information.
Thank you all for your support and appreciated advises
Scott323885155lc0Correct answer
I came here with the same issue. My monitor's recommended scaling was 100%, but the issue was resolved when I set it to 125%.
I have the same issue. It worked until a few days ago, now I can't use Premiere on an external monitor. After Effects works fine, however.
For a temporary fix, you can change the 2nd monitor scale in the window setting.
Have you had any breakthroughs?
I'm having the same issue - I thought I was going mad, as my external monitor was working just over a week ago
Not yet melissa, probably some issues with some OS or software updates compatibilities.
Waiting someone who's going to solve our problem, we wish
Thank you all
What scaling if any is applied to those monitors?
Adobe Employee
February 7, 2025
Hi eugenio_0165,
We're sorry to hear about this. We're investigating a similar issue. Did you install any Windows updates recently? Let us know the exact version of Windows you are using. We're here to help.
Sumeet
Thank you for your response. I am currently using Windows 11 Pro, version 22H2. Please let me know if you need any further details to assist with the investigation.
