Cut 58 seconds out of every minute on a long clip?
I’m making a time lapse of the recent blizzard. Unfortunately the time lapse feature of my little surveillance camera failed, so I have downloaded the micro SD card from the camera and assembled one long 24 hour file out of hundreds of files (the camera records one file every minute and has a crazy directory structure).
With the one long clip, I can just adjust the speed (more than once if necessary) to make a conventional time lapse, but what I’d really like is to have a process that goes through the 24 hour file and skips 2 seconds, cuts 58 seconds, skips ahead two seconds, cuts 58 seconds, skips ahead two seconds, etc. The result would be a time lapse of the storm but showing the full speed video and audio of many 2 second moments of the storm.
I did something like this many years ago but had to do it manually which I don’t want to do. Is there an automated process that will do this, or a keyboard shortcut or macro I could create and press 1000 times or something?
Thanks!
John
