Damaged Premiere Pro Project - Can someone repair/fix it? (HELP - Corrupted Premiere Pro Project)
- March 4, 2023
- 3 replies
- 3258 views
Hello Everyone,
I sadly have a corrupted Adobe premiere pro Project file!
Yesterday I deleted the project together with all the autosaves BY MISTAKE. Then i recovered them (with a recovery software) and since then none of the project files are working.I cant open this project in premiere pro anymore. Is it possible to somehow repair/fix an recovered Premire pro Project file? Im using 22.2 Version of PP on Windows 10.
Can someone repair/fix this file by coding or using his "hacking" skills? ;D
Im also sending here a working file. Maybe that helps find out differences.
Thanks in Advance!!!
Much love
Leo
