grafdeik
Feb 15, 2026 7:55 PM UTC
Delete some effects from clips in effects control panel with Automation Blocks
Sometimes I need to delete some effects from clips in the effects control panel. This takes a long time if there are a lot of clips. Is it possible to automate this using Automation Blocks? The same question applies to transitions between clips—sometimes I accidentally press CTRL+D, don't notice, and then end up doing wasted work.
Mathias Moehl
Mathias MoehlCorrect answer
Jul 1, 2026 7:27 AM UTC
Sorry for the delayed reply. Since the forum migration, I apparently stopped receiving notifications for some Automation Blocks questions, so I’m only catching up on them now.
Paul’s suggestions are the best practical solutions here: for transitions, Sequence > Simplify Sequence with Remove Transitions enabled is a good way to create a clean copy of the sequence without the unwanted transitions. For effects, Edit > Remove Attributes is usually the right built-in Premiere command to try.
Regarding Automation Blocks specifically: currently there is no dedicated block for removing applied effects or transitions from clips. Some effect parameters can be modified via scripting/custom code, but removing applied effects is not exposed cleanly enough in Premiere’s classic scripting API to make this a reliable Automation Blocks workflow.
So for now I’d recommend using Premiere’s built-in cleanup commands for this. I’ll keep it in mind as a feature request, though, because bulk cleanup tools like this would definitely be useful.
Mathias Moehl
Feb 16, 2026 2:54 AM UTC
To remove unwanted transitions, go to Sequence > Simplify Sequence and tick Remove Transitions. This will create a new copy of your sequence without transitions.
Feb 16, 2026 2:51 AM UTC
Would it be easier to just select all your clips and use Edit > Remove Attributes?
