Deleting/organizing Mogrt files?
  • August 3, 2018
  • 12784 views
I'm not sure if I'm just missing something obvious here, but why can't I delete or organize all these essential graphics? I have some that I've made, and some that I've bought, and all the crap stock adobe ones.
When I try and bring in the ones I made/bought, it just merges them in the panel with the adobe ones. I don't want that. I tried organizing by folder. Doesn't carry over. I tried importing vs just manually putting them in the correct essential graphics folder on my computer..nothing. I tried deleting all of the stock adobe ones I don't want that clutter everything up...they all came back.
I deleted them in the essential graphics panel in premiere, then went into the essential graphics AND motion graphics folders on my computer, deleted them, restarted premiere, and they all came back?!
Am I missing something super obvious, or did Adobe just barely build it and not think about people ever actually using it for work? As far as I can tell, thats Adobe's general MO: Make a new feature that barely works in time for the next big release, break a lot of things that used to work in the process, and never contemplate it being used for actual projects in the real world.
    Jeff-fa-fa
    I had a similar issue where I had CG's I couldn't remove from Premiere or After Effects. In my case I created them in AE but still wasn't able to delete them. A search on my computer could not find the .mogrt files.
    I finally figured out that they were saved online in the Adobe Creative cloud documents/library (http://)assets.adobe.com/libraries. Even there, there was no easy way figure out how to to delete them. I finally found out 1) Archive them 2) Delete them from the archive.
    Jeff
    Thank you Jeff!!!!!!!!!!!!!! Make my working day!
    Did you notice the option for Libraries just under the Local Templates option?
    That's where they are anticipating users to group and utilize mogrts from. You can create multiple libraries, move things between them, delete, whatever ... and only the ones in your libraries will show with the Local Templates folder unchecked.
    This is also a slick way for groups of users, as shared libraries are a good distribution means. Everybody gets the mogrts as soon as they're uploaded to the group library/ies, and they are replaceable easily if you say update a logo or slogan, just delete the one and replace with the new one, it works in all users then.
    I would prefer the local folders thing allowed sub-folders and such, and do suggest you add the comments to those others who've posted over on the UserVoice system ...
    Adobe UserVoice Bug /Feature form: https://adobe-video.uservoice.com/forums/911233-premiere-pro
    But how do I add my mogrts to that library? The only way I’ve found is to create one in AE, save from AE, and it appears in Pr....but thats a terrible workflow. Also, why can’t I delete stock ones I don’t want. They take forever to load and are useless
    Click the graphic in the timeline, right-click, Export as Motion Graphics Template, selecting either a local drive folder or a library.
    If you use the Libraries, you don't see the stock ones. Deselect the local driver folder.
