adalbertos.santacruz
detector de escena no funciona
  • August 3, 2023
  • 727 views
tengo la version 23.5.0
lo corro en windows
hago el  procedimiento pero no lo jace el premierre los cortes
que debo hacer para que esto funcione correctamente
agraddesco su ayuda
gracias
Beto
Does your sequence settings match the footage?
both have the same frequency.
Using media encore I converted it to apple prores HQ and it still doesn't work.
also uninstall premiere pro and install it and it still doesn't work.
Dont use AME, use a 3 party converter.
