Difference between constant gain and constant power? (and a suggestion)
  • January 14, 2019
  • 13031 views
for those of us mere mortals, whats the difference between constant gain and constant power?
id like to suggest that a more intuitive term for this would be "crossfade"
and as a feature suggestion, i would be highly intuitive to be able to apply this by simply selecting the two audio clips and hitting "X" on the keyboard to apply it
i have seen it in some Audio DAWs and it works well.
thanks
    Select the cut point between the two audio clips and press Shift + D.
    MtD
    You can do that below.
    Adobe video & audio apps
    But Premiere Pro can already apply transitions to a group of selected clips.
    This page is the top search result from your link but thanks
    nicky9499
    Same here, top result on google. Absolutely detest self-righteous (abuse removed by moderator) like Jim, who even titles himself as "LEGEND".
