Direct Download Links for Premiere Pro 2020
  • March 3, 2024
  • 4 replies
  • 8142 views
Hi! I'm posting to see if someone can help me obtain the 2020 direct download links for Premiere Pro and After Effects? I contacted support as many other community posts suggested but, unfortunately, they said they did not have the links available to them and instead directed me back to community posts to see if anyone else could help (effectively sending me in a circle).....
I would really appreciate it if anyone could direct me to any other available solutions! Thank you.
i need adobe premiere pro 2020
Peru Bob
@mark_mm_4693
Sorry, it's no longer available for download.
Este página Web de ProDesign Tools podría ser de útil.
How to Get the New Adobe CC 2020 Direct Download Links
Byron.
Peru Bob
@Byron Cortez
Those links no longer work.
Ah ok gracias por la aclaración @Peru Bob
Byron.
Peru Bob
Same here. Been using my University plan these past few years so after going back to my old private account, it auto updated Premiere Pro without any warning.
Any help would be greatly appreciated.
Peru Bob
quote
By @Jim5245426426
You can turn off auto update in the CC app.
Kevin-Monahan
Yes but someone else might have the 2020 version available that could send us that zip file. The link is to download a zip file with the 2020 installer anyways. I'm hoping to find someone with a 2020 Premiere Pro Zip file that could hopefully send it to us.
Hello @Jim5245426426,
Thanks for writing in.
quote
I may be able to assist you. Send me a PM.
Take Care,
