Apr 26, 2024 12:10 PM UTC
Disabling language auto-detection stops relinking problems on startup
I wanted to share a learning with you: Over the past few weeks, we faced an issue where starting up Premiere and the process of relinking files was taking a long time, sometimes making Premiere unusable for 1-2 hours or it didn't work at all. We were able to identify the cause today: under Preferences - Transcription - "Enable language auto-detection." When this option is checked, Premiere seems to re-analyze every clip at startup. When it's unchecked, everything runs smoothly.
Hope this might help someone!
Kind regards,
Hendrik
Stan Jones
Apr 26, 2024 8:47 PM UTC
@Hendrik N.,
Thanks for sharing!
Do you have autotranscription turned on in preferences?
Why are the files relinking?
Stan
