Display Surface Initialization Failed - PLEASE Help?
  • September 29, 2022
  • 3098 views
Using Windows 11(64bit)
64GB RAM
Installed on my 'D' Drive (1TB)
Also have a 256GB SSD Drive
Have been using PPro for about 5 months. Now, when I want to load it, I get this message (after a 3-4 minute wait). Other Creative Cloud applications work (Media Encoder, etc.)....
Can anyone offer up some help on this?
Thank you
David Simonton, DVA
Regarding the install location, I think it's unlikely to be causing this issue for you.  The Creative Cloud Desktop application allows you to specify a non-default location, and as far as I'm aware this is a supported configuration.  It's conceivable that the location or permissions associated with that location could factor into a GPUSniffer failure, which is a more likely cause of your "Display Surface initialization failed" error.
In your application's install location, there is a "gpusniffer.exe" file, and if you open a Command Prompt window and run that exe file, it may indicate a failure, and point to a possible resolution for the failure.  If it turns out that a GPUSniffer failure is causing your "Display Surface initialization failure" error, it might be resolved by a driver update, or a system reboot.
The screen cap you shared looks like you're getting this message in AME, not PrPro, but the write-up says AME is working okay for you?  Can you share information about your graphics card(s)/driver(s)?
David,
Thank you for taking the time to post this response. I will run the process you described and let you know how it fares. RE: The Image I posted. ME works fine, for me. I was following someone elses recommendation that I open ME prior to PP and that might resolve the issue. The image captures that it did not work for me. Sorry for the confusion.
James
You need to install all software on the system drive C.
