Stefan-Gabriel
Does a Transaction system exist for modifying a project/sequence in ExtendedScript?
  • December 16, 2021
  • 393 views
Hi!
My goal is to apply many modification operations to a sequence from ExtendedScript and I have a few questions:
1) Is there a transaction system where if something does wrong, I could drop the modifications and leave the sequence untouched?
1.1) If not, such a system could be created by working on a temp sequence clone, but could the clone then overwrite the original?
2) Is there a system to freeze the undo/redo stack while I do the changes so that everything changed is just in one undo step? (All I could find in the QE dom under QEProject are undo/redo/undoStackIndex methods)
Thank you,
- Stefan
Correct answer Bruce Bullis
1. No.
1.1 Safest approach = duplicate the sequence first, and operate on the duplicate. Once successful, you can delete the original (or preserve it in a safety bin somewhere).
2. No; In PPro, ExtendScript operates outside the Undo stack. QE DOM is neither recommended nor supported.
Bruce Bullis
Bruce BullisCorrect answer
1. No.
Stefan-Gabriel
quote
By @Bruce Bullis
Not sure I understand, as every operation I do creates an undo step, is that not supposed to happen?
What about code that runs in the Panel environment, can that help me bulk all ops into one step?
Bruce Bullis
Yes, ExtendScript actions generate undo items; that is supposed to happen. "Outside" may have been the wrong term; "independently of" might be better.
ExtendScript run from within a CEP panel is still ExtendScript, and behaves in similar fashion.
I've added your vote to DVAPR-4235114, a feature request to provide Undo stack grouping capabilities to ExtendScript.
