Needs More Info
Double-clicking timeline clip doesn’t match playhead frame on first attempt (requires a second double-click)
When I double-click a clip in the timeline to open it in the Source Monitor, it does not show the frame where the timeline playhead is positioned. Instead, it opens the correct master clip but displays a different frame — often from another section of the same video (for example, a neighboring cut I made earlier or completely different part of the video nowhere near the playhead).
If I immediately double-click the same timeline clip again, the Source Monitor then updates to the correct frame that matches the playhead position.
This behavior is consistent and reproducible. The timeline clips are all from the same source file, just cut and edited with the Razor tool. Premiere v26.0.1, but has also occured in previous versions just as consistently.
Link to video:
    Use Sequence > Match Frame (F) instead of double-clicking the clip.
    No that is not an option. Don't want the source clip I want the clip that is on the timeline.
    That workaround seems to work for me for now. Even dragging that clip brings a copy of the edited (cut, no effects) clip from the timeline (with or without audio, depending on where I drag) and not the whole source video, which is nice. Either way, as I said in my earlier reply, the bug is still there. I made a video to demonstrate. I’d still love it if Adobe could fix it, as it’s still happening in both Premiere Beta and the normal stable Premiere version. If it is actually a bug and not a “feature” lol.
    I think this is fixed in the beta as I have not seen this in a while.
    Yeah, I just saw your post about it earlier from 4 months ago but haven't  seen any more recent ones. I'll download the Beta and test there. Do you happen to know when the Beta will go live for everyone?
    Adobe does not give a timeframe.
