marathon230
DVD Material nach Import in Premiere Pro CC abgeschnitten
  • March 8, 2017
  • 1439 views
Hallo,
ich habe DVD Material in Premiere CC importiert. D.h. ich habe die gesamte Ordnerstruktur der DVD auf die Festplatte kopiert und dann ganz normal in Premiere importiert. Ich habe auch Bild und Ton, jedoch ist das Bildmaterial an der Seite abgeschnitten. Wenn ich das selbe Material per DVD Player Software abspiele, ist es nicht beschnitten. Was mache ich falsch?
Viele Grüße
Johannes
    Correct answer Warren Heaton
    marathon:
    Have you considered covering the DVD-Video data outside of Premiere?
    VLC Player might be able to do it.  Handbrake is an option if H264 will work.  I use an application called DVDxDV Pro to that converts the VIDEO_TS data structure to DV-NTSC or Apple ProRes every so often.
    Then, import the resulting movie file into your Premiere Pro project.
    -Warren
    Warren Heaton
    Warren HeatonCommunity ExpertCorrect answer
    marathon:
    -Warren
    CS6 one already has. DVDxDV one has to buy...
    marathon230
    ok, thank you for your help!
    converting via VLC works, kind of... ;-)
    But now I know how to handle the problem.
    Post screenshot of dvd in say vlc player and in Program Monitor or Premiere for comparison. To see how much is cut off, as there are different scenarios for this.
    marathon230
    This is the vob file in the vlc player.
    This is the same vob file in Premiere Pro CC
    That is what I thought. This is a bug in Pr that affects some mpeg files.
    Download Premiere CS6, then you will be able to edit the footage.
    Stan Jones
    Is the PR viewer set to "Fit"?
    Did you create the sequence by dragging a vob to the new item icon?
    marathon230
    What do you mean with PR viewer? Is that the zoom factor in the source monitor?
    Yes, I created a sequence by dragging the vob to the new item icon.
    I did also did it by creating the sequence first and than dragging the vob into the sequence.
    But this doesn't make difference. Already the vob source material inside Premiere (in the source monitor) is cut of.
