Encore CS5 motion menu and transition problems (with a motion menu I made in After Effects)
Below is a conversation that I've been having with one user in the community. If anyone else has a solution to this problem, a response to this would be appreciated. Thanks. - Dustin
Thanks you, Stan. The guide on Imgburn.com helped. However, there is still a problem, but I'm getting close. So the Blu-ray folder created successfully. Then I used Imgburn to burn it. It burnt just fine, but when it was verifying it, I got an error message. Something about an unreadable format, along those lines. So I put it in my Blu-ray player, and it reads it as a Blu-ray movie. So that worked. But the main menu is messed up. It's a motion menu that I made in After Effects that I imported into Encore using Dynamic Link. So it's an unrendered AE composition. It's basically just a still image with a 3 minute video playing in the background. I want the video to play with its sound in the menu. The issue I run into is having the video actaully play in the menu since I could only export one frame as a Photohop layers and then import it into Encore as a menu. It's just a still frame of the video. I found a tutorial on YouTube that said to hide all the layers of the menu in Encore, that way when I link the motion video and audio to the menu, it would show the motion menu layered underneath the buttons. Basically without the motion menu and the layers hidden, it's just a black screen with the highlighted buttons. And that's how it burnt the Blu-ray main menu (black screen with hightlighted buttons). There is the audio though, just not the video. I noticed though when I would close the project in Encore, then reopen it later, and try to preview the project, it would show just the black screen for the main menu. Then if I would mess with it and deselect and reselect the layers of the menu and go preview it again, then it would show the motion menu in the preview. So somethng is wrong in the program to not render the motion menu correctly. The video in the motion menu is a rendered MPEG2 standard SD NTSC file that I imported into After Effects. I was thinking maybe that has something to do with it. Or should I just try to render the entire motion menu out as an H.264 MP4 file or something else, and then link it to the menu in Encore (instead of using Dynamic Link)? I've attached a picture on the main motion menu so you can see what I'm talking about. The video that I want to play is in the upper right part of the frame. Thanks.
Dustin,
Congrats on the success so far!
It is tempting to get the AE menu to work, but I think I would just go to a regular Encore or Photoshop menu and export the motion background ONLY from AE as a file. If the file comes in to Encore as Untrnascoded, just let Encore transcode it.
Do a Save As to create a test project. I would start with an Encore Library menu with video background only - I used the Crib Menu HD for testing. Set that menu as first play. Preview. You'll need to render the menu. If that works, replace the Baby Room...m2v background with your export from AE.
See if you can get that to work. Then add the background audio as a separate file.
Stan
Ok, so I watched another tutorial on YouTube, and it showed when you link the motion video for the menu, it should pop up behind the buttons in the menu window. I hasn't been doing that the whole time that I tried burning the discs. So I did what you said and opened a menu in the Encore Library and linked the motion video to that menu, and sure enough it popped up. So the issue has to be with the menu I made in AE. I don't know to make the background transparent to show the motion video. Like I said when I link the motion, it doesn't pop up. Just a black screen. Any possible solution? It's gotta be a setting somewhere. Thanks again.
Ok so here's an update. I went ahead and used a menu in the Encore Library and deleted all the buttons and other assets on it. Then I linked the motion video and audio to it and added my own custom buttons. From there, I rendered the motion menu and previewed it. It worked fine, HOWEVER I have a 4 second transition that goes from the main menu (the motion menu) to the first page of chapters. Well, with the menu I created in AE, the transition worked fine in the preview window. But with the Encore Library menu, it doesn't. It just plays the beginning of the motion video without audio for those 4 seconds of the transtion and then jumps to the first page of chapters. Any insight on how to fix either the menu I made in AE or the fix the transition problem would be appreciated. Thanks.
