ck_rocks
Entire monitor/display goes black randomly during playback
  • December 7, 2021
  • 2734 views
I upgraded to PP 2022, and when I use either playback window, my entire monitor/display will randomly go black for a few seconds during playback, randomly off and on, off and on. Super annoying!
Here are my system settings:
Processor Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz 2.30 GHz
Installed RAM 16.0 GB (15.8 GB usable)
Windows 11
Interstingly... when I tried to record my screen showing how it goes back, the recording comes out looking fine with no blackouts. So obviously a monitor/display issue here. I'd appreciate any suggestions. Thank you!
MyerPj
I get those also. I think mine's in the gtx1070 or the cables. I purchased I high end cable for one of my monitors and then I hardly got the error since, so I never installed it. Lately it's been doing it perhaps a bit more. I need to vacuum / clean inside my computer soon, will probably replace it then.
ck_rocks
ck_rocksAuthor
My PC is an all-in-one so no additional monitors or cables. However, thank you for throwing that out as a possible issue.
ck_rocks, please confirm that you do own a graphics card...
Mike Dziennik
Try going to Help>System Compatibility Report. Is there anything in there?
What GFX card are you using, and what driver? You may need to update.
ck_rocks
ck_rocksAuthor
- no report under system compability
- the display adaptor is an Intel(R) UHD Graphics
- I updated everything within Windows 11 and the advanced driver updates as well within Windows
Hey ck rocks,
The viewers randomly going black is probably related to your GPU tanking.
Next time it happens, go to File->Project Settings->General->Renderer: Software Only
and see if it comes back. And "Intel(R) UHD Graphics" is hopefully not your graphics card...this is the integrated graphics adpter on your CPU, and if this is all you have used so far, I commend you, sir.
Push the windows button on your keyboard. type 'device manager', look under 'Display Adaptors'...
If you only see your Intel(R) UHD Graphics there, install the drivers for your graphcis card.
