Essential Sound panel not filtering Audio Partners
  • August 24, 2021
  • 278 views
My copy of premiere pro (v15.4.1 build 6) doesn't filter the essential sound panel on audio partners correctly. I have a few projects where we need to use music exclusively from Epidemic Sound, as such filtering the essential sound's browse-list on Audio Partner would be a god send. However, as soon as I click any checkbox for any audio partner, the whole list becomes empty. It doesn't matter if any other filers are active or not, the audio partner filtering just seems to result in "no results".
Has anyone else experienced this, and what could be a good way to fix it?
Vishu_Aggarwal
I agree it seems to be broken inside of Premiere pro it does not filter the music using the search or audio partner...So the only option as of now is to go to stock.adobe.com to filter the audio.
You can report the issue here - https://www.adobe.com/products/wishform.html
Vishu AggarwalAdobe Certified Instructor, Professional and Expert
