export bit rate 120
  • March 19, 2020
  • 582 views
Hello again Adobe brain bank,
I have been asked to export a Master for a Broadcaster, but it got rejected by them because the bitrate was to high.  The original Master was a ProRes HQ, but I needed to get a Quicktime, DNX.  My settings are:
I have different options in resolution, should I choice standard quality instead of High?  Also wondering how do I check the bitrate the broadcaster wants in the final Mastered Video?
Thank you in advance.
Might want to look at the export settings again: they are quite a mess as Richard already pointed out.
You may have to try a test, and check from what MediaInfo shows as the bitrate when you drag/drop the file onto that applet's icon on your desktop, and go into Tree view.
I just tried a 1920x1080 into DNxHD SQ ... and got 116Mbps with a 24fps file.
You're taking a 640x360 30p source and exporting it at 1920x1080 25 interlaced, I'm supprised it only failed the QC on bit rate.
Please ignore the source from image, that's not what I was exporting. I am wanting feedback on the output settings only.  The sequence I was exporting was 1920x1080, prores 422.
thank you.
