Export freezing on Premiere Pro 2022.3. (MacOS)
I just re-opened an old project on the most recent update of Premiere Pro, and am having a terrible time exporting it. The basic problem is: Both Premiere Pro and Media Encoder freeze at exactly the same frame during the export, and need to be force-quit. It's 100% repeatable.
The frame on which it freezes is the frame before the start of a third-party transition (BCC Cross Melt), but that exact same transition is used throughout the movie, and prior instances of it are exported correctly.
I have, so far, tried exporting a small range around the problematic area, and that works fine. I have also deleted and reapplied the transition at that cut point, and that does not solve the problem.
Thoughts on next steps for troubleshooting?
[Edited version typo:mod]
