Nov 2, 2021 1:47 PM UTC
Export problem selector 9 error code 3 (H.264)
Hi
I have problems exporting my video in H.264 in premiere pro. I get the notification 'selector 9 error code 3'.
I have a Asus Vivobook 14 with an i5 processor. Before the summer, I had never problems exporting video's to that format. Now I am not able to export it in H.264
My adobe and premiere pro are updated to the latest version. So this will not be the issue.
How do I solve this problem?
Thank you in advance!
Joel SheffieldCorrect answer
Nov 10, 2021 1:28 AM UTC
As an addendum to that message, I found that when I disabled Hardware encoding, through edit>preferences>media it made the editing process impossibly slow.  So I couldn't move around in the clips easily.  My solution was to enable hardward encoding, restart the program, continue my edit, but then, before attempting to export the project, to go back to edit>preferences>media and disable hardware encoding.  This requires a restart of the program, but ok.  It works. I can then export an MP4 file.
Joel
Nov 16, 2021 3:35 AM UTC
I'm having this same problem and waiting adobe launch the 22.1 or 22.2 cause it's starting to give lots of problems here.. we are paying and don't having the service and anyone answer.. two weeks, we did format the notebook, reinstal and that's not the problem.. so Adobe, can you help us?
Nov 9, 2021 11:14 PM UTC
I'm having the same exact issue. Ever since the update, the export goes wrong as soon as it starts on the mp4 files and I get the exact same error code.
Nov 9, 2021 10:43 PM UTC
Same problem.
How to downgrade? In CC app I can't find "other versions" any idea?
Nov 9, 2021 4:33 PM UTC
See if you can export using Software Encoding. It's in the Video Tab of the Export Settings dialog box.
Nov 9, 2021 7:01 PM UTC
As it turns out, I was able to switch to software coding in the Edit>Preferences>Media tab.  When I did that, I was able to export the file.  That change requires a restart of the software.
Joel
Nov 9, 2021 4:31 PM UTC
I have the same problem with the new update to 2022
.  I've tried software encoding, but that doesn't help.  Is there a way to revert to the earlier edition of Premiere Pro?
Mar 10, 2024 9:47 AM UTC
I have the same error, I have this version, and the tip you gave worked for me, Thank you, you saved me.
Nov 2, 2021 7:04 PM UTC
Have the same problem since the new update. You can try selecting Software Encoding instead of Hardware Encoding for this project. It will take a little longer but you can probably export it that way until we find solution for this problem.
Nov 3, 2021 9:18 PM UTC
Hi!
How do I do this?
Verzonden vanuit Mail voor Windows
[http://www.pxl.be/Assets/afbeeldingen_algemeen/MailFootersPXL/PXL_INSCHRIJVEN_2021-2022.jpg]
