Export Selection as Premiere Project
  • July 19, 2022
  • 4 replies
  • 3794 views
In Premiere Pro 2022 (22.5.0), the "Export -> Selection as Premiere Project" is not working properly. In Premiere Pro 2021, when using this export selection premiere would create that specific sequence into it's own premiere project. However, when I tried to use this export in Premiere 2022, it's just exporting out the full project and not just the selected sequence. Does anyone have a solution to this problem?
Correct answer Kevin-Monahan
Yes, it seems to be working in 22.6.2. Let us know if it works for you.
lbernier
I'm running Premiere Pro 22.6.2 and both working in Silicon and Intel (using Rosetta) does not work. I did try on a M1 Pro Macbook Pro, M1 Max Mac Studio and a 2020 Intel iMac all on macOS Monterey. Looking for any updates. Thanks.
Kevin-Monahan
Check out Premiere Pro Beta, Laurent. Is it working there?
lbernier
Hi Kevin, sorry to inform you that it doesn't work in the beta either...
I'm currently in 22.5 and this is brutally annoying. Has this been fixed yet?
Kevin-Monahan
Kevin-MonahanCommunity ManagerCorrect answer
Working for me now
THIS IS SO FRUSTRATING AS AN ASSITANT EDITOR
Kevin-Monahan
Hi Emilia,
Sorry for the error. I can see why you are frustrated. Please install the Beta and update it frequently. The team knows about the bug and is working on a fix.
Any updates on this?  I am having the same issue.
Kevin-Monahan
Hi MC,
Sorry about that. I can help you take action on this.
Can you please upvote these bugs?
https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/45370102-export-selection-as-premiere-project-does-a-save-a
https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/45405397-export-selection-as-premiere-project-does-not-clea
I'll let the product team and the support team know about the issue, as well.
Kevin-Monahan
Hi MC,
I filed an internal bug on your behalf. Thanks so much for alerting me to the issue. I hope this action helps the bug get fixed soon.
