SeeSalt13
Export Sequences with Bin Structure using Automation Blocks
  • January 8, 2024
  • 358 views
If you need to export clips or sequences from Premiere Pro and retain the bin structure as a folder structure, Mamoworld's Automation Blocks has your answer.  The custom Automation Blocks script is attached and a full tutorial is here:  https://youtu.be/Zyh4zk-wUQA
Thanks a lot!
We're having a bug where media encoder says the destination folder could not be found. this would mean that it's not able to write the folder structure. any suggestions how we could solve this?
Thanks!
Mathias Moehl
Wow, thank you so much for creating this tutorial!
