Dec 19, 2024 9:55 PM UTC
Exported audio does not match in Sequence Audio
Hello everyone,
I am trying to export a video but every time I try to export it, it first says rendering audio tracks, takes about 2 minutes (for a 30 second video) and then the exported video the audio doesn't match the video, as well as the audio just keeps randomly cutting. Does anyone know how to fix this?
Dec 19, 2024 10:30 PM UTC
Hi @matt_5202,
Welcome to Adobe Premiere Pro forums. We are glad to see you here! Thanks for the message.
You say you are having trouble with the audio when exporting. I've seen this, but the time is not very long. Something else is amiss. My suspicion is that your audio sample rate from your source is not matching Sequence Settings and Export Settings. See that those three things are aligned based on your source audio and let me know if that helps matters. I sure hope so. Take care.
