Exporting Speed ramped and Warped stablized footage problem
  • March 18, 2020
  • 354 views
When I export speed ramped footage with a warp stabilizer  (WS then nested then ramped) it comes out with a Wierd pixilated motion blur distortion on the frames. This hasn't happened to me before. It only happens on the sped-up bit. I shot the footage in  60fps and have interpreted it to 23.976fps. Any ideas?  see the image, playback is fine in the preview window so I'm guessing it is my export settings.  https://imgur.com/75cOWut
Thanks for any help I'm confused.
here are my settings https://imgur.com/H3lMzox
Warp is one of the heaviest effects on the planet. SpeedRamping ain't no joy for the systems either. Combining them is a load.
When I do need to Warp, much of the time I'll apply that, render/replace the clip with the same format/codec that I expect to export to, and then ... I'm done with Warp.
Might consider this.
Weirdly I fixed it, but not on purpose, I upscaled the whole thing to 4k and exported it like that and it fixed it. Deffo not an actaul fix since it's still doing it on the other version I saved, but for now i think that will have to do as i tried the other suggestion.
Thanks for comments
Your field settings are incorrect HD is never Lower Field.
Set it to progressive: sequence and export
And turn of max render if you have a dedicted gpu.
Also turn off max depth.
Peru Bob
Try speed ramp, nest, WS instead.
