Extendscript change clip speed
  • June 9, 2022
  • 462 views
I've been trying to change the clip's speed via extendscript, however all answers I found all point to it's impossible to do that.
May I ask has the extendscript been updated, and now it's possible to change the clip's speed? Or is there any other way to change the speed via code?
Thanks
Correct answer Bruce Bullis
There is no ExtendScript API to modify clip speed.
Bruce Bullis
Bruce BullisCommunity ManagerCorrect answer
