해결됨
Extreme feather for the ultrakey or transparent parts of an image or video?
  • June 8, 2023
  • 1 답변
  • 490 조회
Frequently while working on some special effects, I may have an image that's been on green screen, but the green screen has been removed with ultra key, alternatively I might have an image like a PNG with transparent portions.
I often wish to feather the edges of the image to an extreme measure until the image is gone. I do not want to blur the image, I simply want to feather and choke the edges all the way down until the image is gone.
Ultra key has a feather and choke feature, 100% only accounts for about 10 pixels. I want to feather the entire screen out of existence. How do I do this? On Final Cut Pro 7 this was an easy feature because Feathering was infinite.
이 주제는 답변이 닫혔습니다.
최고의 답변: Ann Bens
Use a mask with feather from Opacity.
1 답변
Ann BensCommunity Expert답변
Richard van den Boogaard
Indeed. This is the way to achieve what you're looking to do.
