Extreme Lag with 25.3 June 2025.
Experiencing extreme lag. I press play and it doesnt start playing for about 10 seconds. Impossible to edit now.
I am assuming it's the new update as last week the same project worked fine. Timeline is about 35 mins long. no effets just cutting clips.
Cleared Cache, downloaded versions older ( Now trying 25.1) having the same issues with them all. Relinked all media, nothing is working.
Audio and frame errors too. For a prject that worked fine last week I am clueless now.
