Nov 6, 2021 12:25 AM UTC
FAQ: Fix Hanging With After Effects 22.0 Compositions in Premiere Pro 22.0 or Media Encoder 22.0
Edit: The current solution is to update After Effects to 22.0.1. The update is available on the Creative Cloud desktop app.
BADGAL Graphicz Inc.Correct answer
Jan 5, 2022 6:07 PM UTC
Thank you so much! We think we may have found one solution – it's working for us right now but we don't want to get our hopes up. So if anyone can figure out compatablie versions, that would still be greatly appreacite.
Even if it can help for a bit, it may be worth it for some!
If you are using a Mac, it turns out secuirty/privacy settings could be blocking the dynamic link between the programs.
Follow these steps (attached video for help):
1. Open "Sytem Preferences" on your computer
2. Go to "Security & Privacy"
3. Click 4th tab "Privacy"
4. Scroll down on the right hand side to "Full Disk Access"
5. Click the lock and enter your password to make changes
6. Put a checkmark next to "Adobe After Effects" and "Adobe Media Encoder"
7. Restart computer
Good Luck 🙂 Hope this helps!
Nov 7, 2021 1:28 PM UTC
Kevin, I hope this won't affect users on the Win platform. I have no problems with dynamic communication. Leave Win for users. It works faster
Nov 9, 2021 7:25 PM UTC
Baffy,
I found it works OK in new projects. Updated ones are the ones most affected by the bug. If I'm wrong about that, please correct me.
Nov 9, 2021 8:27 PM UTC
Maybe Kevin. I think it works. I would like stability
Random Cat
Nov 7, 2021 12:32 PM UTC
Yep that's fixed it thanks so much >> respect
Nov 9, 2021 7:49 PM UTC
Random Cat,
Thanks so much for your feedback. Helpful!
Nov 6, 2021 4:32 PM UTC
Nop. It doesn't work.... I need to open PP22 with 2 diferent proyects of AE22 and doesn't work any thing I've read in the threads about this issue...
Windows 11 Pro 21H2 every Adobe App Updated 2022
Pablo
Nov 6, 2021 5:59 PM UTC
Sorry ... this is nasty for those affected. For some, turning off the multi-frame rendering is a fix, for others, no help at all. For some, opening Ae and the comps first means when they open and work in PrPro it all works. For others, nope, no help at all.
What the hay?
Nov 7, 2021 1:30 PM UTC
This is how the application is developed, since it is crooked. It should work stably on all operating systems. That's the main question!!! We need to think about it.
Nov 6, 2021 2:08 AM UTC
Dang ... multiframe rendering is SUCH a huge speedbooster in Ae. Very frustrating issue.
Hope this gets sorted soonest of course ... and thanks for posting!
