Adobe Employee
Oct 22, 2020 2:12 PM UTC
FAQ: How to solve issues related to undocked panels in Premiere Pro v14.5?
Update: This issue is being addressed in our Beta releases and will be available in a future stable release. You may download the Beta build from the Creative Cloud Desktop app. Please refer to this link to know more about Beta apps.
We are investigating an issue with Premiere Pro v14.5 wherein undocking panels or splitting workspace across multiple monitors might cause a few features to not work.
These are:
  • Keyboard shortcuts not working.
  • Drag & Drop functionality not working for the clips on the timeline.
  • In a few cases moving media clips to a different track on the timeline causes the media/asset to get duplicated in the project bin.
Workaround to fix these issues is to dock the panels or use any of the default Workspaces under the menu Window > Workspaces. If you have modified any of the default workspace, you may reset it under Window > Workspaces > Reset to Saved Layout.
Hope it helps.
Dominic WitherowCorrect answer
Oct 26, 2020 5:08 PM UTC
Ditto exactly!
My setup has 2 monitors to work within and a third to monitor at full resolution. 'Delete/Clear' buttons not working, dragging anything in the Project panel not working. All fixed by switching to an Adobe preset workspace and then switching back to my custom workspace.
MacbookPro 16" 2019, 2.3GHz, 8 core i9, 64GB RAM, AMD 5500M 8GB, OSX 10.15.7 operating in closed clamshell mode with monitors attached via OWC Thunderbolt 3 Pro Dock and OWC Thunderbolt 3 Standard Dock
Professional film maker/editor since 2004, working on MBP M4 Max 128GB, 4TB SSD
KonnaMcLord
Oct 28, 2020 12:03 PM UTC
My solution that somehow works:
  1. (Workspace > Reset to Saved Layout)
  2. Change to some different standard Workspace
  3. Then back to mine
When I close and reopen Premiere however all is lost again... 😕😕
Scott Bell
Oct 28, 2020 12:00 AM UTC
I'm having this issue as well on a Windows machine. Really frustrating. Please resolve this ASAP.
Oct 28, 2020 3:12 PM UTC
Все начинает работать когда переходишь в одномониторный режим.
Oct 27, 2020 11:05 PM UTC
Having this issue on a Mac and it's crippling my workflow. Please help.
Oct 27, 2020 5:28 PM UTC
I'm having all these reported issues mentioned in this post:
  • Keyboard shortcuts not working. (delete key, etc)
  • Drag & Drop functionality not working for the clips on the timeline OR dragging them in to begin with
Stefan_Gallego
Oct 27, 2020 2:07 PM UTC
How embarassing that this passed your quality assurance. Very disappointing. Huge dealbreaker for workflow.
Using AE since 2004
Oct 27, 2020 7:05 AM UTC
I'm having the same issue with docked panels as well. I've got a 3 monitors configuration and my project panel is on monitor number 2. I can't drag and drop assets within the panel, nor from folder to folder, can't playback from source monitor and all my keyboard shortcuts don't work at all when on monitor 2. This is extremely frustrating, not to mention how much it's affecting my workflow. Any ideas?
jesskaat
Oct 27, 2020 12:45 AM UTC
When will this be fixed??? Having major issues with this problem
Abbottoklus
Oct 26, 2020 5:16 PM UTC
An alternative workaround is to close your undocked window(s), then use Reset to Saved Layout, and everything works again.
Oct 26, 2020 3:59 PM UTC
I have uninstalled 14.5 and gone back to 14.4, problem fixed! Thanks Adobe
Humanclock
Oct 27, 2020 6:31 AM UTC
Ah, so the new fling you met online had a bunch of issues that made your life difficult, so you had to go running back to the ex.
I get it and have been there myself.
[passes zefrey a beverage, gives fist bump]
Oct 26, 2020 9:10 AM UTC
It happend to me. Im working on 3 monitors and lost possibility to 3point editing. When i change my windows setup (WIN+P) to "PC SCREEN ONLY" insert/overwrite starts working immidietly.
