If Premiere Pro crashes, lags, or shows errors, start by updating the software and your GPU drivers. Clear cache files via Preferences > Media Cache. Disable third-party plugins to rule out conflicts. Use Software Only rendering under Project Settings if hardware acceleration causes issues. For playback problems, lower the resolution or use proxies. Reset preferences (hold Alt while launching) as a last resort. Always keep your system and Premiere Pro up to date for best performance.
dion43
I never had issues with 2024, but 2025 is a mess. Any articles about that?
Adobe Employee
June 2, 2025
Hi dion43,
Sorry about the poor experience. Please elaborate the issue you are experiencing with Premiere Pro. We're here to help, just need more info.
Sumeet
After an update I was unable to use Premier. All the videos will show black (audio will play) but no frames. I had to downgrade to an older version to be able to use the application. I tried everything I could find in forums and or Youtube but nothing worked. As of now I am like 3 versions behind.
Thanks for reaching out.
[cid:pre-tec0-91-34-38logo-54_87be0cd4-13a6-4a02-bce5-6d5126b84bf1.png] Diego Ramirez
AutoPatch Proj Execution/Optimization Mgr
PRE-TEC, a division of
The Willamette Valley Company
Eugene, OR
541-606-5036 Cell
[cid:pretec-linkblue_8703b071-d6f8-47a3-930c-b45fd7dab9b6.png]<>
After an update, video previews/ playback will not show (black Screen) audio plays. I've tried reinstalling GPU drivers (Game & Studio), Deleting cache, and Uninstalling and Re-Installing Adobe Cloud and Premier. The only thing that "works" using the "Use Software Rendering only (one time only)" option.  It takes forever to export but it's the only workaround I could find.  It used to work just fine before the most recent update. Any pointers?
Adobe Employee
April 29, 2025
Hi there,
We're sorry to hear about this. Are you still experiencing this issue? If so, please let us know the version of Premiere Pro that you are using & about the GPU and its driver version.
Sumeet
PP 24.6.1 Build 2 not transcribing dialogue - I was getting the watermark transcribed in the music track but it wasn't seeing the dialogue. After some searching realised it was due to mxf clips so the work around is to export and import a wav file with the audio which it saw and transcribed straight away.
bb7775264
Can I revert to previous version? 24 is broken.
I got the same issue. Donwloaded version 24.03 and it doesn`t work. Now, the other versions arent working too, even the system requirements are given. help!
Remote Index
April 22, 2023
Kevin,
One caveat needs to be added. One of his "fixes" relies on using the Interpret Footage command. Using this command is not supported by Adobe if you're using a proxy workflow, and he should mention this when he suggests it.
Come to think of it, he should probably mention the proxy workflow limitations in his list of things to check. (ie. if you have used Modify Audio Channels/Timecode/Captions or  Interpret Footage and you are using a proxy workflow, it could be the source of problems.)
R.
The solutions can only be attempted after the problem is diagnosed. Most users don't know anything is corrupt, they simply have a number of lag issues, crashes, spinning ball and the like... This may as well be un-pinned. I wasted time coming here thinking this would help me and I'm sure others are lead here by the misleading title.
Warren Heaton
Even if everything in Premiere Pro is working as expected, this is a good read for new and experienced users to be informed about the many files that allow the software to function as expected and have a quick reference to refer back to later.
With the list of files right at the start of the article, users can decide to read the whole thing or jump right to a corresponding section for detailed instructions.
Remote Index
April 22, 2023
@Kevin-Monahan
Thanks, Kevin,
I'm interested to know how Adobe is approaching solutions to these "common problems". For example, are there plans to automate each those "fixes".
Edit: I see he mentions a beta feature which addresses 'reset app preferences' in his post, but I'm wondering about the whole list.
R.
Averdahl
This post should be pinned. 🙂
Good idea. I'll do it. I also added a link to it in the main troubleshooting doc at the very top.
