jjc.tri
Fast Forward timeline 2x speed/scrubbing during 2 cam multicam edit choppy
  • November 16, 2023
  • 1867 views
Fast Forward timeline 2x speed/scrubbing during 2 cam multicam edit choppy in Version 24.
When I multicam edit ( 2 cams) I do so at 2x speed (L key 2 times), have done this for years, and worked fine in previous versions of Premiere Pro. now it plays back choppy impossible for me to edit quickly. i have deadlines and need to multicam roughly as fast as possible.  I have tried placing on NVMe drives, and SSD drives to rule out bottlenecks.  Very Beefy System. Specs Below.
The footage is All-I 150 Mbps - no FX added to the timeline.
Windows 11 / Latest Updates as of 11-15-2023 & Latest GPU Drivers as of 11-15-2023
Motherboard:
ASUS PRIME Z790M-PLUS D4
CPU:
Intel I7-13700K Processor
GPU's:
NVIDIA GeForce RTX 3060 Ti
Intel® UHD Graphics 770
Intel® Arc™ A770 Graphics
RAM:
128 GB MEMORY
DRIVES:
Solidigm™ 660p (formerly Intel®)
CT2000P2SSD8
Sabrent Rocket Q
SanDisk Extreme Pro 55AF SCSI Disk Device
SanDisk Extreme 55AE SCSI Disk Device
Micron CT4000X8SSD9 SCSI Disk Device
SPCC Solid State Disk
CT500MX500SSD1
Micron CT1000X8SSD9 SCSI Disk Device
Crucial_CT750MX300SSD1
Samsung SSD 850 EVO 250GB
ST3000LM016-1N217V
Please Help!
Correct answer Michael Grenadier
I have terabytes of available space. The greater demands of an upgrade are insufficient to slow my system down.   i haven't tried importing the project into premiere. That's a good idea. Proxies ill try but no matter what I throw in my time line and multicam edit @ 2x speed it is still choppy...... i would like to know if other users that multicam experience the same issues...
Do you have multiple screens connected to your computer?  That can sometimes cause problems.   Try just using one screen and see if that makes a difference.
if it was working properly in the previous version of Premiere, revert to that...  It's not clear to me from your post what the pixel dimensions, frame rate and codec of your source footage is.  Does it all match?  Have you tried a proxy workflow?
jjc.tri
jjc.triAuthor
The footage is c4k 29.97 ALL I compression 10bit 4:2:2 150 Mbps mp4.
I am not looking to revert i'd like to solve this problem and continue using the latest version for many reasons.
jjc.tri
jjc.triAuthor
ill try that out. FYI - the import project does not help..
