Francis-Crossman
Principal Product Manager
November 25, 2021
FIXED: Export issue for H.264 and HEVC with Premiere Pro 23.1
  • November 25, 2021
  • 435 replies
  • 143689 views
This issue has been fixed in Premiere Pro version 23.2.  Please update to get the fix.
We have identified a file name issue affecting H.264 and HEVC/H.265 exports on Windows with Premiere Pro 23.1
The issue impacts H.264 and HEVC/H.265 exports to folders with names that use double-byte characters, such as Chinese, Japanese, Korean, or extended ASCII characters, like accents and umlauts. Affected users will see this message: File importer detected an inconsistency in the file structure of %filename.mp4%. Reading and writing this file’s metadata (XMP) has been disabled.
If you are experiencing this issue, use one of these options:
  • Please update to version 23.2 where the issue is fixed
  • The following workarounds are for 23.1
    • Choose an export destination folder that uses only single-byte ASCII English characters (no accents, umlauts, etc.)
    • Export to a different format, such as Apple ProRes.
    • For H.264 exports only: disable hardware-accelerated encoding.
Correct answer Ann Bens
Update to 23.2.
I have installed the HEVC code extension from the Microsoft store but having the same problem. Could you please
help?
Kartika Rawat
Sorry about that. Could you let us know the Premiere Pro version? Also, let us know the source of the media files. Thanks. ^KR
Version 23.4 source file MP4 formate  .
I have the latest version and still im having the problems
I'm also having problems until this day.
Hola! Podrías indicarnos si también se solucionó el problema con las actualizaciones de After Effects? Sigo utilizando la versión 22.0 que no presentaba errores y quiero saber si ya la puedo actualizar. Saludos!
Francis-Crossman
February 17, 2023
I'm pleased to announce that Premiere Pro version 23.2 has just been released with a fix for this issue and some other nice features.  Please update to get the fix.
Thanks Francis,
I can confirm that 23.2 fixes this issue.
Amotz28355805
Thank you - saved me a lot of time troubleshooting this 🖖
this -Choose an export destination folder that uses only single-byte ASCII English characters (no accents, umlauts, etc.) - worked, yet it´s quite ridiculous that the last update doesn´t support such characters. Really hope you fix that soon.
xoxo jk
Incrível o descaso da Adobe com o problema. Gastamos dinheiro assinando o software e há quase 2 meses não podemos utilizar a versão mais atual porque ainda não resolveram o problema. Agora, experimente atrasar o pagamento para ver o que acontece...
O Media Enconder foi atualizado para a versão 23.2 e aparentemente o bug foi corrigido. Confere?
Media Encoder was updated to 23.2 and apparently bug was fixed. Check?
Hello Adobe folks,
How can it takes more than a month to fix this ENORMOUS bug ? (And even : how can that kind of bug happen ?)
My Dropbox root folder is name after my name (Stéphane) and I use Premiere to WORK, so I dont want a workaround using software rendering.
Dont ask why people are moving to Resolve ...
Hola! Esta es la solución que encontré. Primero con la versión 23 abrí el proyecto (que ya había sido trabajado en esa versión) y lo guardé como una versión anterior. Luego, ese proyecto nuevo (copia del original) lo pude abrir en la versión 22 y ahí trabajar como siempre.
Igualmente hoy estuve hablando con soporte y me dijeron que el error se da cuando el proyecto (y la exportadación) no están alojados en el disco del sistema. Lo que me parece que Adobe debería corregir.
La captura corresponde a la versión 22, pero en la nueva funciona de la misma manera.
Saludos y suerte!
