Francis-Crossman
Principal Product Manager
November 25, 2021
FIXED: Export issue for H.264 and HEVC with Premiere Pro 23.1
  • November 25, 2021
  • 435 replies
  • 143689 views
This issue has been fixed in Premiere Pro version 23.2.  Please update to get the fix.
We have identified a file name issue affecting H.264 and HEVC/H.265 exports on Windows with Premiere Pro 23.1
The issue impacts H.264 and HEVC/H.265 exports to folders with names that use double-byte characters, such as Chinese, Japanese, Korean, or extended ASCII characters, like accents and umlauts. Affected users will see this message: File importer detected an inconsistency in the file structure of %filename.mp4%. Reading and writing this file’s metadata (XMP) has been disabled.
If you are experiencing this issue, use one of these options:
  • Please update to version 23.2 where the issue is fixed
  • The following workarounds are for 23.1
    • Choose an export destination folder that uses only single-byte ASCII English characters (no accents, umlauts, etc.)
    • Export to a different format, such as Apple ProRes.
    • For H.264 exports only: disable hardware-accelerated encoding.
Correct answer Ann Bens
Update to 23.2.
Nancy-Nalaz
version 23.0 worked for me
Thanks for the information. Since yesterday it troubled me so much, I couldn't find the solution until now. It worked just by exporting to a new directory with a name with only English characters.
It worked for me! Thanks.
Solved used software encoding. Thanks
mariat24077160
This is happening to me and I only use English characters. How can I fix this?
When exporting videos, use "software encoding" instead of hardware encoding.
It worked well for me and solved all my problems.
Melhores Cumprimentos:
António Fragata
Videografia - Fotografia e Video
[personal info deleted by mod]
mariat24077160
Thank you for your suggestion Antonio.
After watching a recent YouTube video I did choose 'software encoding'. However, I've installed an earlier version of Premier Pro and that version is working for me. I won't up update Premier Pro until this issue is resolved in a future update.
I'm also doing some online learning to figure out all the basics to get my head around the jargon and features available in Premier Pro.
Cheers
AugustoFPC
I work around this problem by saving the output mp4 (h.264) file in a different folder than where the Premiere project file is saved.
Even though I use Portuguese characters in the file name and hardware acceleration, the file is exported correctly.
So in my case, I can't export the mp4 file in the same folder as the Premiere project file.
Is good to know! Thx
Ivan Najera
I tried every possible solutions coming from Adobe (and another "experts" forums) but nothing really fixed the issue.
My only personal and possible logical solution was to uninstall Premiere with the lastest version and reinstall the last one when it worked normal, the problem was fixed.
The only thing I guess is not so cool... is to make a step backwards to fix a problem that it is supposed as an upgrade.
Hasta ahora he intentado todas las opciones que han brindado aquí y ninguna funciona, versiones anteriores, formatos diferentes al H.264, exportar en unidades externas, cambiar nombres, crear nuevos proyectos... ninguno me funciona ylo necesito. 😞
Soy de Colombia
Kirmm Ella
¡Oh, pobre alma dulce! ¿Ha intentado cambiar el nombre de la carpeta de salida y el nombre de la exportación? A la versión más nueva no le gustan las letras que no están en inglés. Además, si eso no ayuda, simplemente cambie la versión de Premiere a una versión 22.
The problem was solved, after i disabled the "hardware-accelerated encoding".
Thanks for the sugestion.
Francis-Crossman
December 15, 2022
Glad to hear this worked for you
Hello, I had the same problem. I deleted the new version and installed the old version, which is 22.6 and my problem is gone, I ask you to try
Francis-Crossman
December 15, 2022
Version 23.0 is also unaffected
Please solve it as soon as possible. Is really anoying to avoid accents when my first name and user profile has it.
Francis-Crossman
December 15, 2022
We fully understand the inconvenience and are working hard on a fix.  In the meantime, you can turn off hardware-accelerated encoding.  If that is not acceptable, I recommend rolling back to the 23.0 version.
rlorono
how do I roll back to previous versions?
