Fixing tinny sound
  • December 17, 2017
  • 28047 views
Hello everybody
I have filmed a dance performance and by accident had the input set to mic because I did use the lapel earlier.
For the att setting I had it in 0db.
Consequently the audio I have comes from the little boom mic only rather than the camera itself. I think this is what happened anyway. I use a Sony VG30.
My sound is very tinny and I’d like to see if anything can correct this. It has a lot of African drums in the show and so I’d like to have a video that brings out the bass and richness of sound.
Thanks for your help
    Correct answer stompingground
    Thanks Ann. Actually thanks for helping everyone - I just tried the 'treble' effect and used this to alter the audio without audition... and it worked! I got my good music back!
    I think I'm missing the actual answer... what did you do with the treble effect?
    Can you Dropbox a sample of the bad file?
    Sure, to what address?
    Bad recording is difficult to fix and I think Audition is a better tool for this.
    Might want to head over there.
    Audition CS5.5, CS6 & CC
    stompinggroundAuthorCorrect answer
