Aug 14, 2014 7:47 AM UTC
Flickering footage in Premiere Pro CC 2014 but not in Premiere Pro CC 2013
Hi guys,
I've been having repeated issues with Premiere Pro CC 2014 on Windows. Basically my footage has a weird strobe/flicker when in the suite and when rendered off even although the footage looks fine, unaltered out of the camera. I rendered off the same footage in the 2013 edition of the software and there is no flicker/strobing going on. I've included one of the worst effected shots in CC 2014 and CC 2013 for comparison.I also experience graphical glitches occasionally when rendering. Please watch below:
Premiere Pro CC 2014 - strobing (300% speed, cropped 15%, RGB curve adjustment, software rendered)
YouTube
Premiere Pro CC 2013 - strobing (300% speed, cropped 15%, RGB curve adjustment, software rendered)
Premiere Pro CC 2013 - no flickering - YouTube
The footage was shot on a Nikon D3200 at 1080p 25fps, aperture 3.5, shutter 1/50, ISO 400.
Editing on a
Dell Optiplex 9020
Intel i5-4570 3.2 Ghz
4 gb Ram
Intel HD Graphics 4600
Windows 7
Has anyone else experienced this issue? My suspicion is an issue with either my graphics card or insufficient RAM.
    May 4, 2015 8:57 PM UTC
    Hi CWood and others on the thread,
    We have a customer having this issue who is now on the upcoming version of Premiere Pro in our prerelease program. The flicker problem is no longer occurring for him and we cannot reproduce the problem either.
    It sounds like we have a fix for the upcoming version. Just thought I'd let you know the positive results.
    luckypatofgold
    May 5, 2015 3:34 PM UTC
    Thats great to hear Kevin - can you provide specifics regarding when this release will be available?
    May 5, 2015 4:01 PM UTC
    Sorry Pmarshry, I can't talk about any release dates at this time.
    May 2, 2015 9:51 AM UTC
    Just wanted to chime in that I have the exact same problems on all our Mac Pro's.
    I find I even get glitches rendering out of AE, when the files are brought into premiere pro.
    100% related to CUDA drivers being screwed.
    Never had this problem, it all started for us in late 2014, I believe we made the move to yosemite at the time. Or maybe it was CC2014.
    Considering rolling back to CC2013, for my next project, as I get crashes all the time every day, and its just killer.
    walt_burns
    Apr 29, 2015 2:01 PM UTC
    here's what worked for us:
    Go to Sequence settings / Editing mode: set to custom (rather than AVC Intra..)
    Video previews: set to Microsoft AVI (rather than I-Frame only mpeg..).  Quicktime also seemed to work.
    I also cleaned the media cache data base (Edit / Prefs / Media)
    If that fails, it may help to select field options on each clip / flicker removal.
    Hope that helps
    walt_burns
    May 1, 2015 10:39 AM UTC
    'Render and replace' is also worth a try
    Apr 9, 2015 1:39 PM UTC
    GPU Acceleration has always been the culprit, which seems, lets say, counter productive.  There's a feature that speeds up rendering, but makes it useless. I've noticed it most often with Red Giant Color Suite, but the 3 way Color Corrector has caused issues at times.
    Quadro K4200
    Dual Xeon E5-2640
    64GB Ram
    Win7 Pro
    JeremyBrownPhotography
    Apr 2, 2015 11:20 AM UTC
    I too have a strange flashing when I render a video. I am not sure how hard it is to see here, but it seems like a criss-cross flashing on my video. Seriously frustrating, especially when I need to render this film for a short film competition that begins in three days. Can you please help us understand what's with the flickering please?
    System Specs:
    GeForce GTX 970
    Intel Core I7 - 920@ 2.67Ghz
    2 - Samsung SSD Evo 1 TB Hard Drives running OS and Adobe Products
    Windows 7 Ultimate
    Current Geforce Driver Nvidia: 347.88
    Apr 2, 2015 9:56 PM UTC
    Hi Jeremy,
    Did you add any effects to that clip? If so, which ones? Are you using Adjustment Layers?
    Apr 6, 2015 2:04 AM UTC
    I have a few effects on my clip, not in adjustment layers though. Fast Color Corrector, RGB Curves, Lumetri, Film Convert Pro 2.1 (For Film Grain), and Tint. I disabled the Film Convert Pro 2.1 and it fixed it.
    luckypatofgold
    Apr 1, 2015 4:37 PM UTC
    What's the status update on this guys... Seriously this is a huge issue and because i can't get my project backwards exported to older versions i'm stuck at this point. My suggestion would be to tell your dev teams to drop all new features until they fix this problem. I want to send adobe a bill for the time its taken me to spend jacking around with this issue.
    Mar 29, 2015 7:54 AM UTC
    I have found that I can successfully export my whole timeline as a .png sequence, export the audio separately, then put it all back together in After Effects and render a Quicktime without the flickering.  It's a ridiculous workaround and a huge pain in the neck, but hopefully it helps if you're in a jam with a client or a deadline.
    Mar 27, 2015 3:23 AM UTC
    I can't believe this thread has been going on for so long and there's no fix. I'm not here to unjustly whine...but seriously Adobe, when we hired a third person and upgraded to CC we find out that with the latest versions we can barely render client work. I have read SO many of these threads, it's seems platform independent, video card independent and so on...it seems the only consistency is that it's Adobe software.
    So rather than go into a long list of what I have tried, my system specs, what the possible fixes I could try are (when none of them work - obviously why this thread still exists) and keeping fingers crossed after spending hours trying to beta test what it supposed to be working version - so we can render on deadline and NOT lose a client - how about a serious effort to fix this? I mean for real. It's great that Adobe responds with the intention of help, but there's a lot of people paying for flawed software and there seems to be no end to this.
    Mar 29, 2015 6:44 AM UTC
    ^^This.  Seriously, is this going anywhere?  The workaround I've found is to manually re-conform the entire project in After Effects and export from there, which is obviously not a real solution.  I have to update a project from last month, and I was sure there would be a fix by now!  Imagine my surprise.
    This is an all-graphics project, meaning there is no camera footage to blame, no color correction, etc.. I'm using a brand new factory spec MacBook Pro, so hardly a unique hardware setup.
    The inability export any video from Premiere makes it completely useless as a video editing tool, professional or otherwise. Oh god, do I have to give FCP7 another chance??
    Mar 25, 2015 5:25 PM UTC
    i had same problem,   only solution i could find was reverting to older version of PP
    Mar 10, 2015 9:59 PM UTC
    Has a solution been found for this problem? I experience it only when I try to use the adjustment layer feature. If I apply a color correction to an adjustment layer, my footage flickers. Apply the same effect to the clip itself and no flicker. Obviously this isn't the end of the world for me, but it's really disappointing - I had high hopes for saving tons of time with  the adjustment layer feature.
    Mar 10, 2015 10:11 PM UTC
    Hi Deeder,
    Sorry that you are experiencing this bug. We have assigned the highest priority to this issue and are working on a fix right now. The workaround for now is to apply effects directly to clips instead of using Adjustment Layers. I hope that will be OK until we implement a fix.
    Mar 10, 2015 10:13 PM UTC
    Sure, Kevin. Like I said - not the end of the world, just a bummer.
