ludhall
Font issue when using Titles. Font not correct/visual issue
  • March 18, 2021
  • 716 views
The font I'm trying to use for with the Title Tool is not displaying properly. In this particular case is a Google Font called 'Epilogue'. I've tried to re-install the font as well as updating Premiere Pro. Right now this is messing up my workflow entirely since I have to export pngs from Photoshop.
Anyone know how to fix this issue I'd be really greatful.
I'm using a 2019 Macbook Pro running macOS Big Sur, vesion 11.2.3.
pijbv
Hi there. Having the same problem on a PC. The typeface details have remained the same but it doesn't look the same at all. Puls Premiere has decided to add a drop shadow to all the text Captions and now dumps all the text into one box.
HELP please
Use the Ess Graphics Panel instead.
The Legacy title is what it is Legacy.
ludhall
ludhallAuthor
This works better, but a lot of font weights missing...
Might be a mac (Big Sur?) issue.
Peru Bob
Does the font work OK if you use Essential Graphics to make the title instead of the Legacy Titler?
ludhall
ludhallAuthor
Hi thank you, this does work better, however there are a bunch of weights missing.
