FX30 Lumetri scopes are wrong.....
- July 8, 2023
- 2 replies
- 2678 views
Just as I suspected. Clipping point in Davinci is 100IRE like it supposed to be. And in Premiere its 80IRE. The scopes are off by 20IRE. I cannot use the scopes on Premiere as they are wrong. This means LUTS and color correction could be wrong as well if the clips are being interpreted wrong....I have posted both pics from both premiere and davinci.
I found out what is was. For some reason the sequence settings color space was set to REC 2100 HLG :/..... My clips are Rec 709 and this threw everything off. Never changed it to HLG so not sure why the settings would just do that. I would not have found this without your help Niel from checking the "Auto tone mapping button" it was right above that thanks.
