Gain first then Loudness/Volume?
  • August 27, 2024
  • 3714 views
Hello, I'm trying to set up a process for my audio... my videos are mainly 10 min talking head videos. Should I adjust the gain first for all audio clips,  THEN go to ES and Loudness and AutoMatch, and then once I have done any repairing to check the Volume to make sure it is -6 to -12 dB? I have watched so many tutorials and I am now so confused! Thank you!
Correct answer PaulMurphy
You can actually skip the Gain step because Automatch will take care of that for you.
Also, "-6 to -12 dB" isn't the most accurate way to gauge loudness. Automatch will do most of the heavy lifting, and you can fine-tune any adjustments with Clip Volume in the Essential Sound panel.
As a final step, I recommend using Loudness Normalization in the Export settings to make sure your audio meets the loudness standards for the platform it's being played on: https://youtu.be/GBH0BFvCLAA
PaulMurphyCommunity ExpertCorrect answer
Hi Paul, I sooooo appreciate this, and it makes total sense. I am now following you. Best regards.
PS. It's now 7h11 in my time zone, and your reply has set me off for a great start to the day!
Check out @PaulMurphy YouTube, ThePremierePro. He's very good at the audio stuff, unlike most of the YouTube's I've seen.
Of course, he pops in here on a lot of things.
Thank you! I've found him, and will check out his channel.
