Geforce 1060 card still not showing CUDA in 14.3
  • June 18, 2020
  • 620 views
Hi Guys
I am running Mac OS 10.13.6High Sierra
On a mid 2012 Mac Pro 5.1
2 x 2.4 GHz 6-Core Intel Xeon
I have an Nvidia Geforce 1060 installed
Running the latest driver for my build 17G7024
CUDA version 418.163 installed
I have no problem accessing Cuda Rendering in Premier pro creative cloud 2019
I have downloaded Premier pro 14.3
I have tried everything to get it to see the CUDA GPU in the playback and render field as I’m  trying to access GPU Accelerated exports.
Any ideas or is my system incompatible ?
Tearing my hair out
Thanks
Eamonn
To answer Sumeet's suggestion:
That will not help you at all. If you have an Nvidia GPU that Apple neither supports nor includes at all in its systems, then you will NOT have any hardware acceleration at all whatsoever. In fact, you will be PERMANENTLY stuck in software-only mode.
And all this is because Apple has never officially supported, nor sold any of its systems with, any Nvidia GPU newer than Kepler. The GTX 1060 was introduced a couple of years after Apple had ditched Nvidia (for the last time, to date) in favor of AMD for its included GPUs.
Adobe Employee
June 18, 2020
Hi Eamonn,
We're sorry about this. Starting with Premiere Pro 14.0, CUDA is no longer supported. If you have an Apple-supplied NVIDIA GPU, you can use the Metal Renderer. For more information, see Changes to GPU and DV/HDV support in Premiere Pro on macOS.
Sumeet
I am very sorry to tell you this, but Apple now no longer supports CUDA at all in OSX releases beginning with Mojave (10.14). Accordingly, beginning with Premiere Pro 14, the Mac version now no longer supports CUDA at all. Only Metal, and (in depreciated status) OpenCL. And to top it off, Nvidia is now no longer offering updated drivers at all for OSX because Apple is now no longer supporting Nvidia GPUs in its newer OSX releases.
