Adobe Employee
October 14, 2024
Generative Extend in Premiere Pro
  • October 14, 2024
  • 20 replies
  • 10471 views
Premiere Pro v25.2 introduces Generative Extend
(Previously in Beta)
Adobe's Premiere Pro is getting a major upgrade with the introduction of Generative Extend, a new feature powered by the Adobe Firefly Video Model. This exciting addition promises to revolutionize the way editors work with video clips, providing a solution to one of the most common challenges in video editing.
What is Generative Extend?
Generative Extend is a tool that allows editors to seamlessly add frames to make clips longer. This means you can now easily extend the duration of a shot without the need for additional footage or complex workarounds.
How does it work?
Using Generative Extend is intuitive and works as expected.
  1. Find the clip in your sequence that you want to extend.
  2. Select the Create Extension tool from the toolbar .
  3. Select and drag the edge of a video or audio clip to extend it.
  4. Once processing is complete, AI-generated labels will appear on the clip, highlighting the generated frames.
  5. If you are not satisfied with the initial expansion,   right-click on  the AI-generated label and select Regenerate  for a new variation . You can also use the same dialog to provide feedback on the generated output. The tool uses advanced AI to analyze the clip and generate new frames that match the original content, ensuring consistency in motion, lighting, and overall look.
Things to remember
Generative Extend currently has some limitations that must be taken into account to ensure optimal results.
  • Frame size : The following resolutions are supported
    - 1920x1080 or 1080x1920
    - 720x1280 or 1280x720
    - 3840x2160 or 2160x3840
    - 4096x2160 or 2160x4096
  • You can increase the length. Video can be increased up to 2 seconds, audio up to 10 seconds.
  • Frame Rate : The creation extension requires clips with a frame rate of 12 to 30 fps.
  • Bit Depth:  Currently 8-bit SDR clips are supported.
  • Location of Generated Media:  You can set the location of generated assets in the File > Project Settings > Scratch Disks section.
Authenticity of content
Premiere Pro now supports content credentials. Clips with generated frames can be labeled in Export Settings > General tab > Export Content Credentials.
The Content Authenticity tool can verify images generated by your app. To learn more about content credentials and content authenticity, see the following links .
What is Content Credentials?
Verify content credentials
Why It's a Game Changer
Generative Extend is a major advancement in video editing technology. Adobe uses AI to give editors unprecedented control and flexibility.  Generative Extend solves several common editing problems.
  • Timing : You can now hold shots for extra beats to match audio cues or improve pacing.
  • Transitions : Add a few frames to add handles to handle transitions between shots.
  • Fine-tune editing : Fine-tune your edits without the constraints of the original footage.
Real world applications
Imagine you’re editing a documentary and need to extend the B-Roll to include a voiceover. Or maybe you’re working on a music video and want to keep a few more frames of a particular shot to match the beat. Generative Extend not only makes it possible, it makes it easy.
Try it now!
To test out the new Generative Extend, install the latest version of Premiere Pro from the Creative Cloud Desktop app. Before you use Generative Extend for the first time, read the user guide for the feature  . The creative community is buzzing with excitement, and this tool (and others to come) will open up new possibilities for editors at all levels.
Adobe also offers access to Beta versions to try new features before general availability. Refer to this link to learn more about the Creative Cloud Beta program. You can learn more about the available Beta features & share feedback at our Beta Community page. Here's how to install the Premiere Pro beta:
How Generative Extend Works
How to Create Additional Frames Using Generative Extend in Premiere Pro - Adobe Care
 What are the new AI-generated extensions in Premiere Pro? - Premiere Gal
Correct answer Peru Bob
I hope it becomes available in the next update of non-beta.
So I've booted up prem pro and was greated with all the new stuff and generative extend tutorial so I open it with the astronaut and give it a go only to be confronted twice with the cannot generate image/clip cannot generate error and thats just on the tutorial. So I have no clue as to why. Ive got the creative cloud and have used firefly a couple of times that seems to work fine but not in prem pro at least for me.
Peru Bob
@craig_pell1024
Try updating or rolling back your graphics driver directly from the video card manufacturer’s site. If NVIDIA, do a clean installation of the latest Studio Driver (NOT the Game Driver).
I have .MTS video files. When I try to use AI extend, I get an error message that it only works on progressive field order. Can I change the files or what to make this work=
Real-world boring, but needed application. We make how-to videos for how to use our products, and provide localized voiceovers for our global customers. Would love to see the option to automatically extend the video clip with a static image from the last frame to match up with the voiceover tracks which may need more than 2 seconds.
  1. Click GenAI button
  2. Select end of frame and drag to start of next audio clip
  3. Clip is extended with just a static image.
Yes, it can be done manually, but this is a simple use of automation/ai to save hours of work across many videos in many languages.
Christian.Z
About time!
I see they just announced complimentary generative extensions until June 4, I f they do like Firefly and charge us extra my $70/mo. will be going somewhere else!
@mj
I suspect they'll have a tiered approach.
mj
Harold Silva
Es hora de probarlo....
Comentare mis resultados.
Salu2
Harold Silva B.
@mj
Defo going to give this a whirl!
I don't see any Beta apps listed under Beta in Creative Cloud, except for Aero.  Is this as expected?
I'm on Creative Cloud 6.4.0.361
Mac OS 12.7.2
davescm
Nice addition - thank you 🙂
Dave
Has anyone else encountered threats when downloading the beta?  My Norton picked up a virus, see attached.
Whoa, this is heavy! It most definitely is a game-changer!
