debbie_tomkies
Hardware NVENC acceleration not available with 14.2 SOLVED
  • May 20, 2020
  • 1071 views
I have an NVidia 1060 graphics card which means that I should be able to use hardware accelerated export rendering in the latest 14.2 release of Premiere Pro. However in the export window, the hardware accelerated option is greyed out with a message that my hardare isn't supported. Do I need to do update something else in settings? Thanks 🙂
Correct answer Ann Bens
Maybe you need to update the studio driver.
debbie_tomkies
Perfect, thank you! I thought I was on the latest version, but a new driver came out in April that I had missed. All working now, thanks again! 🙂
