glaustin
Help! Audio Channel Options in Clip/ Modify Greyed Out
  • August 14, 2017
  • 1645 views
Hi guys
I'm in the latest version of CC 2017 and I work with XMF footage. I'm just about to do a multicam edit. As my Sony Z150 captures with 4 tracks, I go into clip/ modify/ audio channel and convert it into one channel for any clips I want to use in multicam. Last time I tried to make a preset, which wasn't successful. Today, however, All the channel options, including pre-sets are greyed out; it doesn't matter if a clip has been used or not in another sequence.
Is there a setting I have inadvertently switched on or off ? Any quick pointers on how to correct, please, would be welcome.
Graham
Correct answer glaustin
PANIC OVER!
It's a Homer Simpson 'Doh!' moment. I was trying to modify the footage from the timeline, not the project bin
glaustin
glaustinAuthorCorrect answer
PANIC OVER!
