Help! - audio effects cause slow-downs and crashes
  • October 27, 2017
  • 5 replies
  • 4858 views
I'm having issues when applying audio effects. When effects are used the system runs slow, sometimes freezes, lags, and will frequently crash. This happens with a variety of different audio effects including Hard Limiter, Parametric Equalizer, Dynamics (obsolete), Multiband Compressor, etc. The heavier the effect, the more effects applied, or the more audio in the timeline, the worse the problem.
This issue has been experienced by both me on my system and my co-editor who is working off of a Puget systems computer. We both have the same specs.
I'm on Premiere CC 2018 and this was an issue I experienced with CC 2017 as well.
Windows 10 Pro 64-bit
CPU
Intel Core i7 6900K @ 3.20GHz 74 °C
RAM
32.0GB  @ 1066MHz (15-15-15-36)
Motherboard
ASUSTeK COMPUTER INC. X99-A II (SOCKET 2011) 77 °C
Graphics
4095MB NVIDIA GeForce GTX 1070 (ASUStek Computer Inc) 79 °C
Storage
745GB NVMe INTEL SSDPEDMW80
60GB TS-RDF5 SD Transcend USB Device (USB)
Audio
High Definition Audio Device
Thanks for the help!
Ok I figured out a fix for this which worked for me but might not work in your situation! Once you've cut up all your audio footage, instead of selecting it all and applying the effects, first
Select it all and NEST IT. Then drop the effects into your whole nested audio clip.
It worked for me hopefully it'll work for you and anyone else who might need it. I know it might not work if only some parts need effects but who knows.
This seems to be working for me so far. Thanks.
It means I need to align all the audio clips that need the same effects on the same track. But that's probably a good practice anyway.
Adobe Employee
September 5, 2018
There are two things you should try:
1.  You are using Windows.  You should make sure that the sample rate of the hardware is set to the same as your sequence.  Most likely that is 48k.  Also, set the Latency to a higher number, from 200 milliseconds to 500 or 700.  See if that helps.
2.  There is a known issue when using automation on the Graphics EQ effect which is used in the Dialog section of the Essential Sound Panel.  If you are using that effect, please either remove it or remove any keyframe automation from it.
-Matt
It is 2020 and I am still having this same issue. I am now using Multiband Compressor and Mastering fx saved as a preset. When audio effects are applied across individual clips in the timeline, the timeline lags. Premire also crashes more frequently.
Please fix this issue!
VonRoeder
We just recently upgraded to CC18 from CC17 and began having the same issues.  It took us a while to track down that it was the audio filters causing the problem.  It really causes headaches on longer projects when it gets used on a lot of individual clips.  I had a half-hour timeline where it would take 5-6 seconds to begin playback once the spacebar was pressed.  Forget scrubbing in the timeline.
We spent hours on the phone troubleshooting with technicians from Adobe and were finally told to wait and see if it was fixed in the next update, or downgrade to the previous version.  No promises that it will be addressed in the next iteration though.
In the meantime we are finding work arounds, like the aforementioned method of adding the filters in the Track Mixer.  Just thought I'd chime in on the issue.
VonRoeder
On the heels of this posting, I got a follow-up from the Adobe technician I was working with:
"I had got a revert from my Adobe Audio Engineering team and this is a known issue as same audio effect is applied in all audio channels making Premiere Pro laggy. We are trying to fix this in future patches."
So, it is something they are aware of.
Jim Simon - We do not use proxies. The work environment is too fast-paced to add creating proxies to the workflow.
I also don't think this should be necessary. I have been using the GH cameras on Premiere since 2010 and never had this issue until switching to CC last year. Adding audio FX should not be too much for a $3000 computer to handle. I'm wondering with the new way CC handles audio compared to previous versions if there might be a setting I need to change that I am not aware of.
GuyUK - this is a good suggestion for when I need to apply an effect to the whole timeline. Unfortunately I will often need to apply effects to individual clips or a group of clips.
That's what I'm saying. Premiere changed how it handled audio from CS6 to CC and now from CC17 to CC18.
Are there settings that I would need to change to keep it from crashing? It would seem counter-intuitive if the changes made the program more prone to system failure than the program in 2010 running the same kinds of files.
What kind of media are you using?
Audio is recorded going from a shotgun mic (both Shure VP83 and Rode VideoMic Pro) into GH4 cameras.
We've experienced the same issue with audio recorded on H1's using a lav.
Got it.
Are you using Cineform proxies?  In not, do so.
Work offline using proxy media |
