Mitzleplick8867
HELP export problem
  • September 1, 2023
  • 428 views
I get this export screen on final export. It gets to 95% complete and I get this screen. Any suggestions?
Correct answer Mitzleplick8867
I changed the export setting from Match Adaptive High Rate to YouTube HD 1920x1080 and that did it.
Yes.
Note it has a timecode? That's because there's a problem at that point in your sequence.
So ... go there, check what's going on. Maybe rebuild it. Then export.
Mitzleplick8867
Mitzleplick8867AuthorCorrect answer
